So, I screwed up, and put too much turf fertilizer on my lawn. It's not completely brown/dead, but there are some pretty significant patches. Is there any way to recover from this? Or is my only option to till the soil and put down new seed?
closed as off-topic by Niall C. Jun 30 '14 at 22:13
  • This question does not appear to be about home improvement within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
Make sure you rule out that the damage isn't from grubs. – BMitch Jun 9 '11 at 19:08
@B Mitch: Well, I haven't seen any grubs while weeding and planting flowers in my flower beds, and the brown spots appeared the day after fertilizing. Am I correct in assuming that this pretty much rules out a grub problem? – Colin K Jun 9 '11 at 19:15
In your case, it sounds like you burned it. Go easy on that fertilizer in the future, the runoff isn't good for the rivers. – BMitch Jun 9 '11 at 22:16
gardening.stackexchange.com - Still in beta though. – electricsauce Jun 10 '11 at 21:57
@ColinK Can't migrate questions older than 60 days: meta.stackexchange.com/questions/151890/… – Niall C. Mar 7 '15 at 5:28
up vote 2 down vote accepted
If it's not totally dead you can try to water it back to health. You should at the very least try this first. Grass is normally pretty hardy and it might survive if you clear the soil of fertilizer.
If it's dead and gone soak the area a few times to try and wash out most of the fertilizer and put some patch seed down. This is the stuff that has the fibers with it to make sure it's not just barren seed on the ground. You could also just put seed down.
If it's the entire yard, you might look into getting it hydro seeded.
In any event nothing is going to continue to grow if it's overly saturated with fertilizer. Fix this first, and then the grass. Water run-off is bad for the rivers and nearby ponds but nothing much can be done about it at this point.
Hey first time home owner here and I just did the same thing. My lawn was a nice dark green. Thick and hardy. And I did the same thing. I know it's not grubs because it's happening all over my yard. Front back and side. :( I'm very hard on myself for doing this. It's just yellow now and I think I noticed it early enough where I'm able to soak the ground and I have a few good storms about to run through town. But because I am so hard in myself I figured I would go and reseed it just incase. So I used Scott's smart seed and their grow anywhere stuff. It contains a hell of alot of mulch as well as some grass seed. So I used a spreader and layer that on heavy with the assumption that the mulch will helphold onto the water to allow the seeds to grow and give the grass that is yellow moisture to help grow back....
Did I do the right thing?
Hi. Lawn questions are now off-topic on this site. Could you repost this a new question on our sister site, Gardening & Landscaping instead? Thanks. – Niall C. Jun 30 '14 at 22:14
