I need to remove a radiator from the wall.
When I set the thermostatic radiator valve to it's zero position and disconnect the outlet of the valve I get a strong flow of water.
The water is definitely coming from the supply side and not from the radiator.
How can I stop the flow / close the valve?
I thought that there was a cap which would screw onto the top of the valve once the thermostat part had been removed - but the plumbing shop told me there was no such thing... If there is, what is it called?
Also it is 30 degrees Celsius at the moment, so the valve should be closed at the zero position... I think... – RobD Jul 1 '15 at 19:06
