I recently made the Yale lock on my front door much easier to open by spraying some WD-40 in there.
However, I just saw this question on WD-40 not being a “true” lubricant, and wondered whether it was appropriate to use on Yale locks?
I recently made the Yale lock on my front door much easier to open by spraying some WD-40 in there. However, I just saw this question on WD-40 not being a “true” lubricant, and wondered whether it was appropriate to use on Yale locks? |
OLD ANSWER (Improved below)
EDIT: As per MrSquonk's comment below -- Try coating the key and work it in slowly. It's less messy.
LATE EDIT: Comment below edited into the answer. Please read full comment thread. Yale USA says:
LAB Lube
For locks that are in such bad shape that one is unable to get graphite powder in it, you can first use a little bit of LPS 1 (Greaseless lubricant). Do not use any kind of silicone lube, that's FAR worse than WD-40 (I had a guy come in with a couple locks he'd done that to, it ended up costing him a good bit of labor for me to undo that mess)! |
This page on YaleDoor.co.uk http://www.yaledoor.co.uk/blog/post/2012/05/01/Home-Door-Lock-Maintenance-Tips.aspx Says the opposite ... "Any, “all purpose” oil or lubrication will do the job, but be sure never to lubricate your door locks with powder graphite, as it will do more harm than good. Simply insert the straw (which is normally supplied with lubricants such as WD40) into the lock cylinder and spray away! " Now I'm confused |
Think of WD-40 as a very good cleaning agent, not a lubricant. If you use WD-40 to lubricate anything, it will probably stick/squeak again in the near future. Myself I use a silicone spray in lock cylinders. Graphite or PTFE might be better or worse, I don't know. |
I just spoke to someone at Yaledoor in their technical department and they advised, 3-in-1 or another 'light engineering oil'. |
