I am going to be painting the inside of my 2-story home except for the bedrooms, so I have a fairly large area to cover. How much more paint would a paint sprayer use, compared to using paint rollers? We are considering using Sherman Williams paint and don't want our expenses to get out of hand.
I have used a sprayer to paint my house before we moved in. While I can't qualify how much more paint I used, it did feel like I used more compared to rolling, but I think part of that is because it goes so quick and I may have been painting over the same areas more than I would have with a roller. One thing to note though, when I sprayed my home, there was nothing in it. No flooring, window treatments, etc. Spraying, no matter how careful, will leave some atomized paint in the air, which will eventually hit the floor or whatever else you don't want to have paint on it. Be prepared to mask, tape, and tarp everything you don't want painted that can't be removed from the room. You will want a mask and a respirator of some kind (you probably don't need anything fancy). The mask I used had a roll of film built in it so that I could get a "clean view" when too much paint got on it. That was especially handy when doing the ceilings. Personally, now that I have moved in, I would roll instead of spray. |
High Volume Low Pressure HVLP will probably be comparable. I have used a High Pressure cannister/gun with my air compressor and wasted a ton of paint to the air. The HVLP sprayers are supposed to be pretty good now. |
