Take the 2-minute tour ×
Is it possible to use an LED bulb in a 3-way light fixture? Will all three work?
Just FYI, an answer below indicates to me that the term "3-way light" is not entirely obvious to readers outside North America. –  staticsan May 17 '11 at 2:19
8 Answers 8
up vote 11 down vote accepted
Unless you have a 3-way LED bulb (and a quick search indicates that they don't exist yet), it will light, but at the brightest light level.
A three-way incandescent light has two filaments: dim and medium. Each filament has a separate contact on the bulb's base. The brightest light level is provided by energizing both simultaneously. When energized, each filament is driven at the mains voltage, so applying that voltage to a standard LED bulb will cause it to produce its rated light output.
You'll probably find that (because the bulb's base is missing a contact), you'll have an "on, off, on, off" pattern as you rotate the switch, instead of "dim, medium, bright, off" like with a 3-way bulb.
Thanks for the help! –  user2676 May 17 '11 at 0:17
the pattern is actually on, on, off, off. if it was on, off, on, off, you would never know because that's the same as on, off. :) –  longneck May 17 '11 at 17:03
Worked it out with an ohmmeter once: 1. ring, 2.center contact, 3. ring and center contact, 4. none. So it's 1. off/dim, 2. on/medium, 3. on/high, 4. off. Works out to the same thing, you have to turn the switch through two clicks to change state. –  Fiasco Labs Jun 23 '14 at 5:10
3 Way LED bulbs finally do exist now: http://store.earthled.com/products/switch-switch3-way-led-light-bulb
I am terribly sorry to contradict two others replying to this question, but I wish to set the record straight on what may be a misunderstanding of the original question.
  1. The question is not about a 3-contact socket which require a 3-contact bulb (with two separate filaments).
  2. The manufacturer's statement: "For incandescent bulbs only" or "Not for compact florescent bulbs" does not mean that you must avoid LED bulbs. That statement may simply mean that the manufacturer failed to account newer LED bulbs...
A 3 way touch switch works by offering a reduced brightness level, but it uses a standard 1-brightness bulb. It achieves the cut-back in illumination by either reducing the voltage or "chopping" the wave form (this is more typical). One very cheap method of dimming a single brightness bulb is to simply skip every other 1/2 wave, as if a diode were inserted in series. But this can produce noticeable flicker and can also cause compact florescent bulbs to overheat.
But to the point: The original writer asks if one can place an LED bulb into a lamp that has a 3-way touch control. The answer is: "It depends!...You must test it!" Here is the reason...
First, LED lamps are typically marked dimmable or NOT dimmable. As of 2014, most screw in replacements from the major brands (CREE, GE, Philips) are dimmable, if they are "equivalent 100 watts" or less. However, they require a dimmer than chops the leading or trailing edge of the waveform. As an example, they require a more expensive wall switch dimmer than the standard incandescent dimmer ($20 as opposed to $10 for a comparable model). So part 1 of my answer is to use only an LED bulb that is marked "dimmable".
But part 2 is trickier...
If you purchased a lamp that says to use incandescent only, you should test it with your LED lamp. In my Hampton Bay model 494 595 upright accent lamp, one brand of LED bulb shines only at full brightness, yet produces an annoying hum at the dim step. But another LED bulb works just right, at half and full brightness. I would mention the bulb model, but they are store brands, and Home Depot is known for switching suppliers or MFG series without changing the SKU or model number. Therefore, these details would be short-lived.
The bottom line, is that (a) It is likely that the touch-dimming circuit is compatible with many LED bulbs, and (b) You must still test the bulb to see if it dims. If it does (and if it does not make noise), it is very likely that the electronics in the bulb "realize" that a dimming circuit is being used, and so the bulb is cooperating by doing the dimming within its own circuitry. Therefore, you should be fine!
Philip Raymond Massachusetts
If it is a 3-way touch fixture, you're right -- it's a dimmer. However, I don't see that in the original question. So you may be right, or the folks you're disagreeing with may be right... and as long as you're saying they are wrong rather than that they may be wrong and this is another valid possibility, I can't up-vote. –  keshlam Sep 6 '14 at 20:59
are you talking about a 3-way switch in a desk lamp? if so, that will be fine. those work by adding a second set of contacts in the base of the socket that if the bulb is a 3-way bulb then it touches those extra contacts. those contacts provide exactly the same voltage as the other contacts.
in short, this will not be a problem.
I have a 3-way fixture that I use a regular dimmable LED bulb in. The 3-way fixture is plugged into a dimmer switch that is plugged into the outlet. It works just fine.
Apparently there is now a three way LED bulb http://www.cnet.com/products/cree-three-way-led-bulb/
Welcome to the site. Link only answers are discouraged, as they are susceptible to losing all content in the event of a broken link. Please include more details in your answer. –  Doresoom Jan 26 at 14:54
HEHE I made my own 3 way LED. I had a popped CFL and carefully removed the curleycues to get the base. I then put in two LED drivers (from 120VAC) and two LEDs which were 5 watt and 2 watt. I think luxeon stars. It works, albeit not as good as I would like. The LED drivers are tiny and did fit into the CFL power supply base.
This doesn't seem to answer the question –  Steven Jan 6 '13 at 3:49
-1 since the question was about using an existing LED bulb rather than building one. Also, CFL's contain mercury, so it's not advisable for others for break them intentionally and you didn't provide the procedure to connect the LEDs. –  BMitch Jan 6 '13 at 12:32
This Q&A from GE, regarding CFL bulbs, should apply for LEDs as well: http://www.gelighting.com/na/home_lighting/ask_us/faq_compact.htm#three_way
Basically, unless the bulb was designed to work in a dimmed context, and says so on the package, you should NOT use it with a dimmer or in a three-way fixture.
Here's a hybrid CFL/LED 3-way bulb: superiorlighting.com/product_p/19030led-tcp.htm –  MT_Head May 16 '11 at 18:47
well LED's are entirely different construction from CFL's, so it is unlikely that the Q&A will apply to both. Thanks though. –  user2676 May 16 '11 at 19:15
Here's a PDF from the Department of Energy you might find useful/interesting: apps1.eere.energy.gov/buildings/publications/pdfs/ssl/… "LEDs face a dimming challenge similar to that of CFLs: their electronics are often incompatible with dimmers designed for incandescents. An LED driver connected directly to a line-voltage incandescent dimmer may not receive enough power to operate at lower dimming levels or it may be damaged by current spikes." –  MT_Head May 16 '11 at 19:23
CFL and LED are completely different. CFL's require ballast starting (internal) at a constant voltage. LED's operate on low voltage (internal step down). Remember what Ass u me means? Sorry, down vote. Be careful, what you give as advice or an answer should be based on fact or personal experience. –  shirlock homes May 16 '11 at 21:42
Although CFL and LED are completely different technologies, they both require constant voltage, which is why they can't be used with standard analog (incandescent) dimmers. To dim an LED, you turn it off and on many times per second (pulse-width modulation, or PWM), and your eye essentially averages the dark/light periods into an approximation of dimness. To work with an incandescent dimmer, your LED bulb needs a microcontroller that converts a lower incoming voltage into a lower PWM rate - which most don't have! Apologies for the link, but I stand by the advice. –  MT_Head May 16 '11 at 22:10
