Tell me more ×
I have a gas oven which has given up the ghost and I want to replace it with an electric pyrolitic oven.
Do I need a separate circuit for the new oven, or can I put it on the normal ring main.?
The new oven says it needs a "hard wired" connection. What's that?
DON'T DO IT MAN! gas ovens are way better (in my opinion). more efficient, better more even heat, faster boil times. Stay with gas, or you'll probably regret it later. – Tester101 May 6 '11 at 12:14
Most cooks prefer electric ovens, gas ranges. – DA01 May 6 '11 at 13:21
Not to mention, you can use them when the power goes out. – Doresoom May 6 '11 at 13:22
The phrase "ring main" makes me think you're in the UK, correct? – Vebjorn Ljosa May 7 '11 at 21:17
I'm in Australian. 240V, 50HZ AC – WOPR May 11 '11 at 1:42
show 1 more comment
1 Answer
up vote 7 down vote accepted
You need a separate circuit for the oven as it draws a much greater current than the normal ring main.
This site explains the load a cooker draws.
A 240 V domestic cooker has the following connected loads:
top oven 1.5 kW
main oven 2.5 kW
grill 2.0kw
four hotplates 2.0 kW each
This results in a nearly 30A load which will clearly overload the regular 13A ring main.
A hard wired connection is where the connection is permanent and not through a normal plug and socket.
Usually though the cooker will only be able to run the oven OR grill/broiler at the same time - so often 20A. In europe (230V 13A) you can get stoves that do not need a separate power line BUT are set so that you can't use the oven and 2 large rings at the same time. – mgb May 6 '11 at 15:54
