My incoming water pipe is copper and it is a brand new installation with no leaks. But due to the hot humid weather (even in the basement) it sweats due to condensation. Should I insulate it?
The problem is last year I insulated some copper pipes only to find a year later that they all corroded due to the water trapped between the pipe and the insulation.
Insulation can cause too much moisture on the pipelines and this moisture can cause corrosion, especially to copper and stainless steel pipes. – plumbing Aug 27 '11 at 11:55
up vote 7 down vote accepted
I wouldn't bother insulating your incoming cold water pipes. If your basement is warm, the water will warm up a little passing through it, but the solution to that -- if you need it -- is to let the cold water run for a little until you're see water that hasn't been sitting around in your pipes getting warm. I say "if you need it" because I generally don't care what temperature my cold water is: drinking water for me comes from a pitcher in my fridge; tap water is used for washing food, mixing with hot water for bathing, or watering plants.
If you're concerned about the condensation from your pipes dripping onto things, I'd be more inclined to get a dehumidifier and run it while you've got this hot, humid weather.
+1 for the dehumidifier suggestion. – BMitch May 5 '11 at 19:52
I'll have a dehumidifier for sure. Maybe I'll leave the pipes alone after all. – Peter Q May 5 '11 at 22:30
The only reason to insulate your incoming water feed is if there is a risk of it freezing during the winter, in which case it's essential.
If it's properly insulated - i.e. there's no gaps in the insulation and there's no gap between the insulation and the pipe then you shouldn't have a problem with condensation as there'll be no way the warm moist air can get to the cold pipe.
