Tell me more ×
Does anyone have any bright ideas for how to open a drawer that has become jammed shut because it has been filled up too much? I've had a look at the underside and can get at the bottom of the drawers but unscrewing the rails etc. is not an option because I can't get at them. Currently my best plan is to try and remove or cut out the hard board base of the drawer which would then need to be replaced. Any better ideas much appreciated.
can you get the drawer open even a quarter inch? – allindal May 1 '11 at 0:16
I can get it in enough to get a bent wire coat hanger into the drawer. Unfortunately poking around with the hanger did nothing to help free the drawer. – Ian Turner May 1 '11 at 7:47
The question doesn't say if the drawer is in something freestanding or fixed to a wall, so FWIW: I've opened a jammed-full drawer in a nightstand by picking up the nightstand and shaking it so things settle further back in the drawer. – Niall C. May 1 '11 at 13:39
It's in a fixed kitchen unit so picking it up or moving it is not an option – Ian Turner May 1 '11 at 15:02
Try to slide something flat in that is the width of the drawer. I've used a plastic flexible cutting board for this purpose before. Slide it open that 1/4 inch, and try to get the flat sheet to ride over whatever is jamming the drawer--you may have to nearly close the drawer with the sheet in place to get it up and over.
Remove the drawer beneath or above the stuck draw. If you can get beneath it, push up against the drawer bottom and rattle that thing around. If you can remove the drawer above the problematic one, well, your problem should be before your eyes.
If you can reach the underside of the drawer, I would remove the screws that hold the drawer to the rails. With a little bit of maneuvering you should be able to drop the drawer down a little and start to pull items out of the top.
up vote 1 down vote accepted
In the end I had to stitch drill a hole in the base of the drawer until I could get my hand through the hole to move the items in the drawer. Having taken the drawer out it is obvious it is very badly designed and there is no other way of dealing with it.
