I have a light pine dining table. After we got married, we left an orchid from the wedding on the table while we went on honeymoon, giving it a bit of water before we went. Didn't realise the pot wasn't water-tight! The water leaked out onto the table and has created quite widespread water damage which obviously wasn't dealt with early.... Can anyone suggest how to get it back to a lovely even finish? Haven't tried any stains yet as wanted to get advice before I tried anything.
Some background, there are two types of wood water stains. White rings and black marks. White rings form when the water has only made it into the finish, this is the "best" kind of stain to have. Black marks occur when the water has penetrated into the wood itself. This is slightly harder to fix and will ultimately require either sanding or covering it with a richer, darker stain, although sanding is the only sure-fire method. There are some options that involve staining or not, I'll start with the least invasive. White ring removal
Black mark removal
