Through different conversations with family members and friends, I have been told that it is good to apply a coat of car wax to the outside of the air conditioning unit frame. I assume that this is to maintain a protective seal and prevent corrosion. Has anyone done this before? I just bought a new Trane XR15 unit in April and I want to keep it in tip-top shape for as long as possible.
I have seen outside units whose paint has faded and become chalky-looking after several years of service. I suppose waxing it might prevent or delay this, but I agree with Doresoom that the benefit is really going to be mainly cosmetic. |
I seems to me that waxing the outside of the AC unit is only going to protect cosmetic appeal. If you're interested in keeping the unit looking nice from the outside, then it could help. Otherwise, I wouldn't put in the effort. |
If you do this, make sure you don't get any wax on the coil! Doing so would hurt the unit's performance. As others have said, this is totally a cosmetic thing. It won't help the life of the unit much. When the unit needs to be replaced, it will be because the coil or compressor is busted (probably 15yrs from now), and you've decided it isn't worth repairing. It's not going to need replacement because the frame has some surface rust. |
The Trane unit has a special coat of paint that will make it look good for years and years, I doubt you will need to wax it. |
I've never heard of this before. Does it mention anything about doing that in the maintenance guide for your unit? If not, then I probably wouldn't bother. |
This will decrease your capacity and efficiency As stated http://www.ccacac.com/maintenance-tips/tips/maintenance-homeowners-can-do/ it talks about just weeds, and dirt much less a thick coat of wax.
I'm assuming you're talking about the condensing unit sitting outside? I'd say you'll wear out the unit long before the frame becomes damaged enough to affect it's function. |
