My bedroom hollow core door hinge holes on the door are completely stripped out and the screws fell out, my remedy I am going to try is as follows:
Remove the door, place hinge side up, apply Fiberglass compound , (Type you get at a Auto. parts store) directly into the holes and also spread onto the area that is recessed for the hinge, set the hinges in place while wet, apply slight coating on top of the hinges as well.
If all goes as planned I hope to find the hinges fiberglassed in place for a very long time and for added security drill a pilot hole and put the screws back in please.
