Take the 2-minute tour ×
I recently moved to my first home (with a modest yard). The previous owners left behind about 20 cinder blocks. I'd like to build something constructive with them in lieu of discarding them. Any suggestions?
I was thinking about a BBQ smoker. Is that possible with cinder blocks?
Any ideas or useful links will be much appreciated.
share
Shelves? –  Tester101 Apr 8 '11 at 16:10
Depending on your location, build a planter. This included the base and the wall surrounding it. You could do a traditional rectangle or something modern like these...
share
where'd you get these photos from? They're great. –  SamtheBrand May 8 '12 at 15:16
You could build an outdoor fire pit. Be sure to check with your local fire regulations first; depending on your location, the fire pit might not be allowed, or there might be restrictions on when you are allowed to use it.
share
You could make a small seating area with benches made from cinder blocks and blocks for side tables; it'll be nicer if you top the cinder block structures with something comfortable to sit on.
A quick web search turned up:
  1. cinder block furniture projects,
  2. hand make outdoor furniture
A smoker might work, but the blocks are very porous; you're going to build up smoke in the walls, and you're going to have a hell of a time sealing the gaps between.
share
Thanks for all that useful info. I am finding conflicting info about the use of cinder blocks for a smoker; what you're saying makes sense. There's something compellingly postindustrial about using the cinder blocks for indoor furniture. Will have to float that idea with the wifey. :) –  Gingi Apr 8 '11 at 17:21
This site is currently not accepting new answers.
Not the answer you're looking for? Browse other questions tagged .
