I recently built a large double wood gate using 6x6x8 posts. Each post was set with concrete in a 26" hole. After some settling, one of the posts is now leaning about 1/4 inch toward the middle. This is causing the gate to not open/close easily. What is the best way to adjust the leaning post? Or do I need to redo the post setting entirely?
Tell me more
My first thought is a guy wire from the top corner of the post, with a turnbuckle in the middle to tension it up and pull out that lean in the post. It seems that if you don't do something like this, the only alternative IS to reset the posts, which is a lot of work. Hope this helps. This is what a turnbuckle looks like:
Why not stick a 1/4" shim behind the gate's lower hinge? Or planing off 1/4" behind the upper hinge? |
