I am putting up a pine PT post fence in front of my home. The fencing is new and green and I would like to stain it a natural wood color.I don't want to put it up green or wait for it to dry or turn a more natural color for a year. Any ideas?
If you stain it now, it will change the end color of the wood. You have to wait for it to turn natural, so either wait six weeks or put it up green. The outside environment will dry it faster than sitting in a pile. Reasons Green lumber accepts stain poorly, while older wood absorbs stains relatively well. The porosity of wood can vary greatly, even within the same piece of wood. Green treated wood refers to lumber infused with chemicals that delay or prevent deterioration. These chemicals reduce the possibility of wood rot. Unfortunately, they also infuse the wood with deep-set moisture that prevents uniform stain absorption. Let the green treated wood sit and dry out before attempting the project. Test the stain before committing to full-scale application, or you'll end up with disappointing results. PS: Make sure your sealer is water- and UV-resistant and contains anti-mildew and anti-algae agents to help the wood stand up to weathering effects. |
You really should wait at least a month or so before staining, in my opinion. However, if you really want to get it up and color it now the only option I see is to stain it now, wait for it to change color when the wood is finally seasoned, and then stain it again. I recently stained my pine fence, but it had been up for almost a year (too long), so I had to pressure wash it first. I used a power sprayer and it went pretty smoothly. |
