So we had a roof leak and water was slowly dripping through the exterior wall and drywall. It had been going on for years, but until recently it became noticeably during a heavy rainfall when the water dripped through the drywall.
So my contractor came out and fixed the roof leak and replaced the drywall and insulation. However underneath the drywall my contractor used Copper Green Wood Preservative (contains 10% copper naphthalene), as he claimed would help maintain the wood since it had been getting wet for years.
When he sprayed the Wood Preservative there was a noticeable strong odor, which he said would go away. It has been a three days since he sprayed the internal wall with Wood Preservative.
I researched online that this product is supposed to be only used for exterior use only. Is there any way I can mitigate this issue.
I am thinking about calling my contractor back and having the dry wall removed and re-installing a new one with painting an odor remover primer behind the drywall and adding HVAC tape.
Let me know if it is worth the extra money I put into this? Also just curious if I leave it as it is, is there any concerns I should have like side effects on health issues for using this product indoors?
