Tell me more ×
The sink has one existing hole, and 3 knockouts which are cut about half way through the material.
What are the best tools, and techniques for removing fixture knockouts on a composite granite sink?
1 Answer
up vote 1 down vote accepted
Well Tester, as brutal as it seems, the prescribed method by FRANKE is to use a blunt ended large punch and a hammer. Set the punch dead center in the cutout and strike it soundly. Don't be too tentative, give it a good shot!! When i first saw my plumber do this on a kitchen job, I cringed! but it worked well. Weren't there any instructions with your sink? i'm just relating the way FRANKE recommends, maybe your brand might have a different method.
So no use for a carbide hole saw? After forking over that kind of cash, I'm tentative to smash it with a hammer. – Tester101 Apr 1 '11 at 13:40
Do you place the punch on the top (where the sticker indicating there is a "hole" there), or the bottom (where the partial cutout is visible)? – Tester101 Apr 1 '11 at 13:57
the instructions say on the top. . If you already have the saw, then pilot a small hole dead center from the side already drilled then finish it off from the top, using the pilot hole. – shirlock homes Apr 1 '11 at 14:27
And let us know how it goes! – aphoria Apr 2 '11 at 11:02
Had my friend knock it out, before telling him how much I paid for it. It did indeed just knockout with a punch and a sharp whack. – Tester101 Apr 5 '11 at 11:58
show 1 more comment
