I just bought some 1/2" plywood from HD for a project, and the best piece I could find was still pretty warped. Is there a way to fix this? Currently, it's sitting flat on my garage floor with a sheet of 3/4" plywood on top of it. Other than adding more weight (maybe some half-empty paint cans?) is there anything else I can do to help it flatten out?
What are you planning on doing with it? Generally, you nail or screw the plywood to something, and that gets rid of the warp. |
I ended up leaving the warped 1/2" plywood under the 3/4" plywood and some paint cans for about a week. The plywood was visibly less warped afterwards, and almost lies flat on the ground with just a slight arch in the center. Not sure if it was significant, but it rained a few of the days, so humidity levels might have played a factor. |
(adding this because I came across it while reading about installing plywood T&G subfloor) A warp means the convex face is larger than the concave side. Set it out on a sunny day, with the convex face towards the sun. As it dries, it will shrink. To help things along, add moisture to the concave side. Either a light misting of water (spray bottle or hose) or lay it on the ground, exposed to the earth's moisture. Watch closely, because if you leave it too long it will warp the other way! |
