Hope this is on topic for this stackexchange.
I recently bought a lamp from the US and had it shipped to Australia. Stupidly I powered it straight off the mains through an adapter. The device is rated at 120V 60Hz and Australian mains are 240V 60Hz. The lamp turned on for a split second and wouldn't power on at all after that. The device has a fuse in the back of it that appears to still be whole, the manual says this should be replaced if the lamp no longer dims correctly.
Have I written off the device or is it possible that it has remained intact? (I know it is impossible to say definitively but some information would be of great help)
I did this with a Dremel once. That was visually stunning. – Andrew Heath Mar 30 '11 at 6:10
+1 for introducing me to a new term that I will incorporate into my vocabulary directly, "boned" – kmm Apr 2 '11 at 15:27
up vote 5 down vote accepted
Does the device have a transformer or similar internal electrics?
If so there's a very good chance you've burnt it out. The fuse only protects against excess current - not incorrect voltage.
I'm not sure about the electrical internals, but it is a reasonably expensive and sophisticated lamp so it's quite possible. Since it is expensive is it worth taking it to a repairer to have a look? – radman Mar 29 '11 at 22:26
@radman - it couldn't hurt. A decent place should look and quote for repair without charging you so you won't have lost anything. – ChrisF Mar 29 '11 at 22:28
