Tell me more ×
What are the tools that every DIY'er should have? This is a community wiki as there is no one right answer.
Instructions:
  • One item per answer (so they can be voted on - answers with multiple items will be voted down)
  • Clear formatting like this:
    [ITEM NAME]
    [Reason why item is essential/useful/good]
    [Photo / other info]
share
show 1 more comment
locked by Tester101 May 3 at 20:29
This question exists because it has historical significance, but it is not considered a good, on-topic question for this site, so please do not use it as evidence that you can ask similar questions here. This question and its answers are frozen and cannot be changed. More info: FAQ.
1 2 3
A laser level (a cheap one will do just fine).
alt text
share
I've used mine a handful of times. They're really handy if you want to keep multiple items in a straight line, especially over a long distance. I found it really handy to do the line of wall anchors for a whiteboard, for example. – msemack Aug 4 '10 at 15:16
show 2 more comments
Chalk Line
Snapping, setting out straight lines.
share
(A high quality) Combination Square
Transferring measurements, marking out 90° & 45° angles, scribing parallel lines...
share
Sledge Hammer
When a normal hammer just won't do.
Sledge Hammer
share
Toolbucket. Love mine. It's amazing what all you can get into one of these.
share
(Sharp) Pencils
You need something to layout, set-out, all those cool DIY projects you are going to do.
Don't forget a pencil sharper, if you can't get a good sharp point via a knife.
share
Shrinking tube and hot glue - use them all the time.
The combination of shrinking tube and hot glue makes smooth, sealed and water-proof solids of any basic shape. Ideal to create custom-shaped plugs or jacks.
share
Cordless (circular) trim saw. Fits into tighter quarters, better for making short cuts than the full-size circular saw.
alt text
share
I've wondered about power issues for the cordless versions. Anyone know about this? – Doresoom Aug 5 '10 at 18:00
A battery-driven saw with a smaller blade just won't have the torque and cutting power of a full-sized saw with a full-powered motor -- that's physics for you. That's why I have both saws. But the smaller one gets used 10 times more often than the larger saw... – Craig Trader Aug 30 '10 at 19:10
show 1 more comment
Cordless 18v lithium ion impact driver. Drives screws and bolts so smoothly, quickly, and without torquing your wrist. Also relatively light, small, hangs on a belt, and battery lasts a long time.
Makita BTD144 is one good example.
share
show 1 more comment
A good Do-it-yourself book.
Reader's Digest "New Complete Do-It-Yourself Manual"
share
show 1 more comment
(A good quality) Handsaw
Don't underestimate the usefulness of this old school hand-tool.
share
Stud finder.
In case you need to hang something that requires more support than a drywall has.
alt text
share
Duplicate. Adam already beat you to this one. – Doresoom Jul 28 '10 at 14:41
show 1 more comment
Toolbox
You need somewhere to store, organise and keep safe all those essential DIY tools.
share
Plumb-bob
Sure you can use a Spirit Level to check if something is plumb, but there are occasions when a Plumb-Bob just makes more sense...
share
Palm Router
Cheap enough for most DIYers, you can pick up a good quality one for around $100.
Has enough power (normally about 1HP) for most DIY jobs.
Can be used to make a variety of DIY projects around the home that much easier.
share
A Diamond Sharpening Stone
For honing and keeping those plane blades, wood chisels, knives, etc good n' sharp.
share
Nail Pincers & Nail Bars
Makes pulling out nails a breeze.
share
1 2 3
