Tell me more ×
I have sliding doors for a wardrobe, and i replaced the roller-wheels. Now they stick at the top, its as if they are too close together. I replaced the wheels in the same spot on the door, but they are slightly different brackets for the wheels, so I'm not sure if its just a matter of me trying to find the "sweet spot" to screw the wheel-bracket, or if its something else I should be looking at.
Any chance you can post a picture or two, showing how they are sticking? – gregmac Mar 20 '11 at 16:05
i'll get a photo, they are rubbing together at the top because they are too close together, which I don't understand because I only put new rollers on. cheers. – campo Mar 21 '11 at 22:01
is it possible that the rollers are the wrong thickness or could they be on backwards? – shirlock homes Mar 22 '11 at 9:29
Thanks @shirlock homes the rollers were a wrong thickness whic was part of the problem. – campo Apr 2 '11 at 3:02
1 Answer
up vote 2 down vote accepted
Thanks for everyone that asked questions. There were a few things I had to change to finally get it working. I had just bought the house and I assumed that the previous owner had the door's rollers fitted properly, basically I had to:
  • Use the old wheels and brackets as the ones i purchased were not sticking out the same length
  • The wheels were put on the wrong side of one of the doors
  • The bottom guides were not screwed in the correct spot
  • The wheels had to be adjusted as they were not the same height
Once all of these factors were fixed the door finally worked!
