I need to build a headboard in the next couple of days.
My requirements:
  • can be attached to the wall, I read something somewhere about French cleat
  • needs to be attached to the bed, to stop the bed from sliding on the hardwood floor (its very old and needs to be refinished so I'm not worried about scratches).
I have limited access to big tools, since it is winter (no garage) and I have about 2 ft of snow in the backyard. I was planning on getting the cutting done at Home Depot or Rona or wherever.
Any suggestions?
Do you mean "french cleat"? newwoodworker.com/frenchcleat.html – James Van Huis Mar 8 '11 at 19:47
yes, lol. thanks James. – cbrulak Mar 8 '11 at 19:49
What kind of bed frame do you have? – Niall C. Mar 8 '11 at 19:51
Is there some reason that you want to build vs. buy a premade headboard? – James Van Huis Mar 8 '11 at 19:54
@James: cost mostly. My wife and I have seen headboards for about 100-150+ and I know plywood is much cheaper. – cbrulak Mar 8 '11 at 23:03
Simple solution.
Materials:
  • Plywood sheet.
  • Quilt batting, Upholstery foam, or similar.
  • Fabric.
  • Fabric glue.
  • [Optional] Buttons and heavy thread.
Procedure:
  • Cut a sheet of plywood to the proper size. You'll want it to start below where it will bolt to the bed frame (about an inch or so), and extend to your desired height above the bed. and you'll want it the width of the bed.
  • Round off the top corners (the size of the arc is up to you), for this a jig saw works well.
  • Drill holes in the plywood to match the bolt pattern of the bed frame.
  • Cut your batting to the same shape as the plywood (Note: the batting does not have to extend below the top of the mattress (but it can it you like), so it might be shorter than the plywood), a utility knife should work just fine for this.
  • Attach the batting to the plywood using spray fabric glue.
  • Wrap the whole thing in fabric, use a stable gun to fasten the fabric to the back of the plywood (make sure you pull the fabric tight, starting from one corner and working your way around).
  • [Optional: For buttons] If you want to add buttons to the headboard to make 'dimples', it's easier to figure out where you want them before hand and pre-drill two small holes for each button in the plywood before you apply the batting, you can drill the holes after wrapping the fabric but you have to be careful.
  • [Optional: For buttons] Using a large needle and heavy thread / string, push the needle through one hole in the plywood until it comes out through the face of the headboard (fabric side), loop the thread/string through the button and then feed the needle back through the other small hole in the plywood.
  • [Optional: For buttons] Pull the thread tight to create the desired 'dimple' depth, and tie it off to hold it. Repeat this procedure for each button.
  • Attach the headboard to the frame, and enjoy.
Here's a good tutorial for a whole bed, complete with dimensioned drawings: ana-white.com/2011/01/lyds-no-sew-upholstered-bed.html You could probably just build the headboard and bolt it to your current frame. – Doresoom Mar 10 '11 at 16:03
