Take the 2-minute tour ×
I recently installed a new kitchen sink and faucet. It was one of those with the spot for a dish detergent pump.
After getting everything in, I come to find out there just isn't enough room to fit the bottle for the pump.
What I need to do is cut about 2 inches of wood that is about 1/2 inch thick, however, it's in a very awkward position.
Are there any suggestions on what I could use to cut?
A picture might help –  gregmac Mar 7 '11 at 21:01
@gregmac - I'll see want I can do. –  John Giotta Mar 7 '11 at 21:04
add comment
up vote 9 down vote accepted
Do you have enough room to use an electric drill with a 2" hole saw? If not, perhaps a Dremel or similar tool with a routing bit?
I do have enough room. I also have a Dremel. The hole saw might work, I was focused on something the that cut down or across and in. –  John Giotta Mar 7 '11 at 18:40
add comment
Keyhole saw might be your friend here. I actually have one where I broke MOST of the handle off so it fits smaller spaces :) For those in need, here is a picture of one: http://en.wikipedia.org/wiki/Keyhole_saw
add comment
Like @Niall I would first recommend a Dremel tool (if you don't have one or can't borrow one, it's a sound investment for any DIYer's toolbox!).
Alternatively, a new oscillating tool by Bosch is made specifically for small, hard-to-reach jobs like this. You might want to check that out as well.
I actually have a Dremel rotary and a multi-max (oscillating). The problem I had with the oscillating was I created more a friction fire than actual cutting LOL. I'll definitely try the routing bit. –  John Giotta Mar 7 '11 at 19:05
add comment
If there's enough space to tap a hammer you could also try a chisel. I've found myself getting out the chisel now and then for tight situations.
A great "less power" solution. –  Tester101 Mar 19 '13 at 15:53
Unfortunately, there wasn't enough swing space for a hammer. –  John Giotta Mar 19 '13 at 16:03
add comment
