I have an alarm mounted at home, which I don't use (it was installed by previous owners). The annoying feature is that it turns on after every power failure (i.e. when the power comes back - its rubbish enough not to have any internal power source). How can I disable it? The only thing I know about this unit is the name 9448 written on the main panel.
Tell me more
Most alarms are plugged into a transformer, which is plugged into the wall. Easiest way is to find that, and disconnect it.
If there is no transformer, and it is hard-wired directly to mains power, then you have a couple options:
It could also be hardwired to an external transformer (like a doorbell is), though I've personally never seen an alarm installed that way. If so, same options as before:
I actually found in a different forum that the reason the alarm turns on after a power failure is because the battery (that I didn't even know about) is dead. I ended up replacing the battery and it is ok now. |
