Are there any guidelines or rules of thumb for how many screws i should use when screwing two pieces of wood together?
For example if i have a 2cm x 10cm plank i want to screw onto a 10cm x 10cm post. Then how many screw should i use and is there an optimal patern the screw should be placed in?
link|improve this question
feedback
up vote 3 down vote accepted
I don't know if there's something for screws in wood, as wood's a rather strange material.
For bolts into steel, however, there's the AISC Manual (no prices listed, but expect it to be in the $300+ range); there used to be a separate book on joints, so you could calculate the strength based on the size of the fastener, bolt pattern, etc. There was also a section for calculating the strength of different weld patterns.
Now, the rules for the optimal strengthy are going to be similar -- further apart will support a greater moment, so when the contact patch is a square, you want the first two to be in opposing corners. If using four, fill all of the corners. However, because it's wood, you have a chance of spliting, so you don't want to go too close to the edges. (if you have to; pre-drill).
The other thing to remember is that with screws and bolts, the fasteners shouldn't be taking the full load -- they're pulling the structural material together, so that the load's transfered as friction ... this means if you see a gap between the two pieces, you need more fasteners. If you have a really large contact patch, drop another screw in the middle.
link|improve this answer
feedback
It's going to really depend on the load the joint is expected to carry.
For your example two screws should be enough if there's no or only a light load, but if the plank was expected to bear a significant weight then a third screw might be advisable. You'd also need to use longer and thicker screws too.
As for a pattern, again it depends on the usage. Screws in line tend to look neater, but you should should probably screw across the diagonal or use a shallow "V" shape for increased stability.
feedback
or
required, but never shown
