I'm building a small shelf for organising my desk, using sections of 42mm*19mm hardwood. I've cut the pieces to appropriate length using a hand saw, allowing some tolerance for the kerf. Now I'd like to ensure the cut ends are square.
Using a sanding block with some garnet paper, and a try square for checking, I'm trying to shape the cut edges. However, I'm finding it difficult to get a good perpendicular line with the sanding; it seems that I'm rounding the end off too much, rather than sanding perfectly perpendicular to the piece.
Back in high school woodwork class, we'd do this with a disc sander mounted into a solid table, ensuring that the sanding is done in a flat plane. Unfortunately, having left high school some 13 years ago, I no longer have access to one of these.
So, does anyone have a good technique for sanding the edges square? Or should I give up on sanding and use some other method? Or bite the bullet and buy a small disc sander?
