I turned off the water at the main cutoff valve in the garage to replace the gaskets in a single handle shower faucet. I got it put back together but when I turned the water back on, I get nothing anywhere in the house. Checked the meter and it is not moving at all. Anyone have any idea what is going on?
Further information. It is a gate valve and I'm pretty sure it's the original that came with the house which is about 17 years old.
up vote 3 down vote accepted
Is the main valve a gate valve? If so, you'll probably have to replace it. These types of values often fail when not used for a long time, and either won't close or won't open again after being closed.
You may be able to repair the valve, but you'll have to shut the water off to do that, so you might as well just replace it with a new valve. If fact, you should replace it with a ball valve (aka quarter turn valve). Ball valves are more reliable, and typically don't break from not being used.
It is a gate valve. Edited question to add this information – Kevin Aug 2 '14 at 17:33
Bad gate valve was indeed the problem. New ball valve installed. – Kevin Aug 2 '14 at 20:54
