Tell me more ×
Do you know of any origami techniques or related cheap alternatives to save or store things like socks, kitchen stuff or other small objects without having to buy heavy and expensive furniture?
@Lev -- I had the same thought when I first saw this question. Just don't go posting pictures of things you make online, as FedEx doesn't like that – Joe Feb 18 '11 at 14:17
Wow, awesome! I didn't know about that Fedex furniture stuff. Awesome, indeed. – João Ramos Feb 21 '11 at 11:13
This question is a bit of a non-sequitur. Socks can be stored in pretty much anything, and I'm not sure what origami has to do with it all. – DA01 Nov 7 '12 at 9:55
closed as off topic by DA01, Niall C., Steven, BMitch Nov 9 '12 at 16:14
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
up vote 1 down vote accepted
as in paper? ... hope not :)
but there are websites that can be helpful in reusing stuff we already have / receive from others
http://www.ikeahackers.net/
is one of them.
Bloxes can be made into shelving, furniture, decorative items, etc.
The only downside is that they are quite expensive.
There are two things, first you want inexpensive stuff and second you want a heavy product means durable. Both objectives are hard to achieve at the same time but still we try.
I only suggest here about kitchen stuff.
If you want to make kitchen cabinets,shelf, pantry cabinets then you may go for particle board. Buy particle board and use it as your core material for creating cabinets. Particle board is much inexpensive and durable. After that you may hire a carpenter to make all cabinets.
Hiring a carpenter probably won't fall under the "inexpensive" category – Steven Nov 7 '12 at 17:44
