I noticed today that there is a nice long yellow line of snow below my eaves. It stretches for several yards, and seems to have been caused by the melt coming from our roof. Aside from thousands of squirrels having urinated on my roof (doubtful) what could be causing it?
There are lots of things that can cause yellow, discounting flying dogs and squirrel infestations. Are there a lot of trees around? Leaves may have collected in your eaves trough, or in other places on your roof, and seeped in enough water to cause discoloration. It could also be something else on the roof - as Eric mentioned, soot is a possibility, though I don't think that would be yellow. Are there any mines, paper mills, power plants or other sources of airborne contaminants nearby? |
From here
So sounds like either leaching from the asphalt under the roof, or could be soot from a wood stove (or fireplace possibly) if you or a neighbor has one. |
rust! If snow touches rust it often imparts a yellow or orange color to it. check for rusting metal around where you see your yellow snow. |
