Tell me more ×
I've got 18 month and 2 1/2 year old boys. I'm considering purchasing a TV, and I'm concerned about the occasional lapse in judgement. (e.g.: The odd toy being thrown at the screen in a fit of uncontrolled anger) What material would be easiest and ideal for protecting my 46"-55" screen from infrequent projectiles. (I'm not expecting it to have to take a huge beating, but it should be able to deflect a pen or maybe a matchbox car)
The clearer the better, but my guess is I can get rid of the protector in 18 months or so anyway, so this is not a permanent solution.
I've seen the following, but was hoping to get in a little cheaper (particularly since the 55" version is $240)
I'm considering a basic acrylic, but not sure if this is the best choice or not.
I've worked with acrylic, but never trying to cut pieces that large ... I'd be inclined to get it cut at the hardware store if you can, as it took me a few tries to figure out how deep I had to score it before cracking so I'd get a straight break. (if it break to the side, if it's larger than what you need, it's really hard to clean up the edge ... if large, you can try a brake for bending sheet metal, but a lot of sanding is generally best.) – Joe Feb 9 '11 at 13:40
up vote 4 down vote accepted
You could use a sheet of Polycarbonate Lexan, It will stand up well to projectiles.
When you no longer need it, you could convert it into a whiteboard as @Peter Bridger did.
Go with Acrylic, as you suggested yourself. It's cheap, durable, flexible and easy to clean.
Out of curiosity, have you used acrylic (or any other coating) yourself? I'm not doubting your answer, but I'd be interested in any personal experience you may have had. – Phrogz Feb 9 '11 at 5:46
Not for this particular type of application. But I have used it before for windows, and it is very easy to work with. – trip0d199 Feb 9 '11 at 13:18
+1 I liked both answers, it strikes me that this line was indeed unanswerable. I thought there might be some incontrovertible fact which swayed the answer in one direction or another, but it turns out no. – altCognito Feb 10 '11 at 23:26
