I had a leak in the roof of my garage in the corner. I called a professional to come and fix it, so the leak is now fixed. I was left with a hole in my ceiling inside the garage. I proceeded to investigate it and removed tons of moldy drywall. After doing this, I attempted to patch all of it up with new drywall. This is the first time I have put up drywall and I realize now how difficult it is to measure these pieces, I have a feeling irregularly sized pieces are required to make it look really perfect, while I cut pieces that were as perpendicular as I could make them.
When I put up the drywall, I realized that the pieces have evident gaps between the seams. I googled it a little, and I saw one person saying to "pre-fill" these gaps. The problem is, I don't know what the rule of thumb is for the size of these gaps. I didn't realize, but I read somewhere that it's better to prefill these gaps before taping.
I have a couple of ideas on what to do now:
1) remove the drywall by unscrewing it and attempt to cut new pieces of irregularly shaped drywall, put it back on and I am hopefully good.
2) pre-fill these gaps with joint compound, but the question is, are my gaps too large? What is the rule of thumb for the maximum size of a gap?
I am wondering if my drywall job is really that terrible, at first glance, it doesn't look like I did a good job.
Can someone advise on drywall gaps and how to handle them correctly?
ceiling and wall drywalling
side corner
larger gap on another side corner
I'd say you did a decent job for a first timer. Looks like the ceiling will be fine with joint compound and tape. But, the corner gap in the bottom photo, well really the whole corner gap, would best be covered over by metal corner bead before applying joint compound. Anyway, that's what I'd do. – getterdun Jul 9 '14 at 3:17
You raise a number of issues.
How to fill an irregularly shaped hole?
To cut drywall (or any panel) to an exact shape with non parallel sides is hard. So what we usually do is make the hole regular. You can trim away some of the remaining drywall, preferably so the edge runs along the middle of a stud, parallel to another stud or the corner. Then cut a rectangular patch to fill the hole, leaving about 1/8 inch gap.
How to make a patch sit in the same plane as the wall?
In general, we want the whole wall to be on the same plane (when you place a straightedge on the face of one section, it sits flat on the adjacent section, neither gapped or raised). If a patch will sit below the level of adjacent wall, you can put shims behind the patch just thick enough to raise the surface to flush. You can use trim boards or tapered shims to get the right thickness, tack them in place with brads, and drill through them when installing the drywall. If the patch sits above the surface, its usually best to use thinner material (but don't violate fire laws about minimum thickness).
In your second picture, the patch looks like it is about 1/2+ lower than the wall. You should shim it out. Even though you could use tape or drywall corners to cover this zigzag, it's a weak, thin joint and will look odd.
How big a gap is acceptable?
Between panels, 1/4 inch is fine. Taping compound and tape will cover it with little difficulty. Putting on a coat of compound before setting the tape will fill the gap. If you are using mesh self adhesive tape, forcing a bit of compound through the tape into the gap couldn't hurt.
If you have a gap that is approaching 1/2 inch or more, you can run into a problem with shrinkage and strength in the joint. Consider recutting the patch. You could use a thin sliver of drywall to partially fill the gap before taping, but it will be a bit more of a challenge to get it level and smooth.
Great answer. Another tip that works for both maintaining plane and re-enforcing the edge on any hole is to use a piece of backing -- like some scrap plywood or 1-by material -- and screw it to the back of the existing drywall, then screw the new drywall to it as well. It will keep them aligned and add strength, and makes it easier to install and tape. – gregmac Jul 8 '14 at 15:45
@gregmac That is the method that pros have always used when the joint is not on framing. It's been taken to the next level by commercial backer boards claiming to work for butt joints on on full sheets better than an on-stud joint. – bib Jul 8 '14 at 17:57
What material is normally used for drywall shims? I was checking online at home depot and there are some pretty expensive shims out there, are these just cardboard that I can get by cutting a box? – paneerlovr Jul 9 '14 at 14:44
If you need more than about 1/2 inch, use a piece of board, either a 1x2, furring strip or a scrap of trim molding. The precision leveling is best done with shims, tapered flat boards about 2 inches wide, 6 - 8 inches long and tapered from about 1/32 inch to about 1/4. They are sold in a pack. By laying a pair of them with their tapers facing in opposite directions, you have a flat surface that can be varied in thickness. – bib Jul 9 '14 at 14:52
To fill a gap, you can cut a custom size piece of drywall (or wood) with a JIG SAW. It creates an amazingly clean cut with incredible accuracy even for very thin slices. The Jig saw works great for cutting holes in drywall (just make sure there's nothing behind it if you're cutting in the wall... -- watch for electrical/plumbing hidden in the wall before you cut... very easy to cut a chuck out of pvc and not know it until the bad thing happens). Good luck – Dan B Aug 30 '15 at 17:39
My dad always mixed in some plaster of Paris with regular old blue top mud. Dried harder, less shrinkage, stronger seams, less cracking. Add water to plaster until it turns grey then mix it in with mud.
Depending on what's behind the gap (if anything), I sometimes tear newspaper into about 1-inch pieces and mix it into some joint compound. The newspaper acts like an aggregate and forms an incredibly strong filler once it dries. In fact, you'll swear it's concrete if you ever need to rip it out. If you're in a hurry you can always use a hot mix compound.
