I live in a rental property where some of the rooms (living room, and bedroom) are situated right next to the street.
I would like to block the view from the street so people looking in can't easily see the insides of my apartment - it's ok if people looking into the room from the street you can see the outline/shadow of people who are inside. I have some pull-down blinds (similar to http://made2style.files.wordpress.com/2012/04/dsc_03271.jpg) which can block the view but these also prevent the sunlight from coming into the rooms. Ideally I could block the view but allow some sunlight to still pass through.
Any suggestions on how to go about doing this? As I am just renting I'm looking for a simple solution - perhaps some kind of screen which I can temporarily prop up against the window?
What kind of blinds do you have, and did you try adjusting them so the slats point up towards the sun? – BMitch Jul 6 '14 at 11:19
Venetian or 1" mini blinds seems like what you need, that's what BMitch is referring to. – Jack Jul 6 '14 at 13:20
I currently have pull-down blinds on the windows rather than venetian blinds (just edited question to reflect this). – Bob Jul 17 '14 at 7:56
Sheer curtains are the traditional solution... – keshlam Jul 17 '14 at 13:44
up vote 1 down vote accepted
Static-cling (clean window, apply with water and a supplied squeegee, no actual adhesive, peels off when you leave without a fight) "stained glass" plastic films are available. They look pretty much as good or bad as you make them look, which is mostly a matter of how carefully you cut the edges. I did a bathroom over with them this spring, and it's a huge improvement over the blinds it used to have. The particular version/brand I used was "ArtScape" and it was found most affordably via Amazon, though HD does carry some of the patterns, but at a higher price.
Why not use cellular shades?
cellular shade
They are fairly cheap, easy to install, admit a good amount of light and obscure the view.
They are also available with a top down feature (for extra money) that allows you to lower the top portion to allow in light but block the view from a parallel point.
 Links and images are for illustration only and not an endorsement.
bib - obviously just trying to sell some blinds on the side. – DMoore Jul 17 '14 at 13:31
@DMoore If I got a nickel for every product I linked or illustrated, I could buy this site! (And think how rich Tester101 would be!!) – bib Jul 17 '14 at 13:50
