I used a good quality name-brand spray can of 'Paint & Primer' to paint a glass lamp, but after the second coat an 'alligator' texture developed in some areas. I followed the instructions before spraying the second coat, and the temperature was about 76 degrees. I haven't been successful in removing the paint (the instructions say to use Mineral Spirits - but it is not working, most likely because the paint has dried). Does anyone have any other suggestions? NOTE: Scraping is not an option because of the texture of the glass.
up vote 1 down vote accepted
Lacquer thinner does a number on many paint finishes. Use it generously and out in the open, it is very flammable. Don't breathe the concentrated fumes either, being outside should prevent that.
Saturate a rag, and give it a go. Dipping is possible too.
Acetone took care of the problem. – RET Jul 1 '14 at 0:06
There are citrus based paint removers that are less harsh on humans and surfaces than conventional solvent based strippers. They take a bit longer, but are worth a try.
citrus stripper
 Images and links are for illustration only - not an endorsement of a product or source.
I tried 100% Acetone, and it worked with a fair amount of 'elbow grease'. Problem solved. – RET Jul 1 '14 at 0:05
