This is definitely a conundrum: not even our local hardware store could figure this one out! So, here goes:
We have a fairly new one-piece toilet in our guest bathroom that now takes forever to refill its tank! Note that there isn't a problem with the bowl refilling...that fills up fairly normally and rapidly. Also, this is a relatively recent change: this toilet actually used to be the fastest flushing toilet in the house.
Here is what I checked:
  1. A visual inspection has uncovered no cracks/leaks from the tank portion of the toilet.
  2. No problems with the flapper valve (we aren't getting plagued with random "ghost flushes", and the flapper appears to be seated well and sealing properly on each flush).
  3. The water valve is fully open.
  4. Just for the curious: the other toilet continues to flush normally.
Here's where the puzzle comes in: based on all of these observations and watching the problem toilet in action, it appears that the problem is the overflow tube, which I have never heard of (nor anyone else). The fill tube running from the fill valve is stationed to run water down the overflow tube--as I understand it, this is normal and is what allows the bowl to refill. But when flushed, it takes over four minutes for the tank to fill.
Here is another reason I suspect the overflow tube: it just so happens that the clip holding the fill tube in place over the overflow tube is wearing out. One time when I had the tank cover off and was repositioning the refill tube back in its proper place, on a whim I decided to hold the refill tube outside of the overflow tube, so that it would send its water directly into the tank, and flushed to see what would happen. The toilet bowl and tank filled rapidly--as one would normally expect--and shut off promptly.
What in the world is going on here? I appreciate any serious guesses!
up vote 3 down vote accepted
The overflow tube drains directly into the bowl, not the tank. The only way I can think that it would prevent the tank from filling is if it was cracked or had a hole in it and allowed tank water to drain into the bowl. If this was the case, you would notice the fill valve cycling if it was a slow leak or never shutting off if it were a large leak. The reason the tank fills quickly when you divert the bowl refill tube into the tank is that you are simply not splitting the water from the fill value between the tank and bowl any more.
It sounds like your fill valve assembly is the problem. The fill value has 2 outlets, one that directs into the tank, and the other that sends water into your bowl refill tube. My best guess is that something inside of the fill value got clogged with sediment, hard water deposits, or something else that restricted it. These are relatively cheap to replace and likely not worth the time to clean them out in my opinion.
This was the answer! A second hardware store (with more knowledgeable personnel than the first one I went to) confirmed this even as I was asking for the proper part...they wanted to be sure I was getting the right thing. Replacement was relatively straightforward, and now everything works like a charm! Thanks for all your help! – Superion Jun 30 '14 at 20:41
I had the same issue! I just twisted the refill pipe which tightened it and it worked fine after that
We're looking for long answers that provide some explanation and context. Don't just give a one-line answer; explain why your answer is right, ideally with citations. Answers that don't include explanations may be removed.
