I have noticed significant grease buildup on the bottom of my Whirlpool dishwasher's door. The dishwasher was purchased brand new in the early 2000s.
I have heard that someone has already tried adding vinegar during a wash cycle to no avail. A quick check of the water temperature with a thermometer reveals a hot water temperature of about 105 degrees Fahrenheit from the nearby kitchen faucet.
Furthermore, the problem happens even after I turn on "HIGH TEMP WASH".
What measures can I take to prevent the problem from recurring after cleaning off the buildup?
rinse your plates off – DMoore Jun 27 '14 at 6:03
If the grease is building up, you might not be using enough soap. And I agreed on pre-rinsing, the more you do in advance, the less strain you put on the dishwasher water filter. – BMitch Jun 27 '14 at 12:15
Some dishwasher require a hot water feed to boost the temps inside the dishwasher. Check your water supply specs. – Jack Jun 27 '14 at 15:13
I'm very reluctant to try pre-rinsing because the purpose of a dishwasher is to wash dishes. I tried having the dishwasher warm up the water to the required temperature to no avail. – Zian Choy Sep 2 '14 at 5:06
@ZianChoy all dishwashers have practical limits as to what they can wash. There's a wide range, unfortunately. Some lower end models truly do need you to pre-rinse the plates beforehand. – DA01 Sep 2 '14 at 5:58
up vote -1 down vote accepted
The answer was:
  1. Use an Affresh tablet once in a while.
  2. Wipe down the bottom of the door periodically.
(In other words, give up and move on with life.)
