We have a problem with psocids in our bathroom, which like to feed on mildew. They come and go out of gaps and holes in the shower grout. I am thus under the impression that there may be mold and mildew behind the tiles.
I have been reading a lot about removing grout and redoing the grout between our tiles. If there is a mildew issue behind the tiles, will re-grouting will be useless? I want to get rid of the cracking and crumbling grout to seal out bugs, but am afraid to seal in any mold or mildew. Any suggestions that don't include a full bath makeover?
This is the current state of the shower ledge, where it seems to be the worst
Grout on top of grout will not last and is only a temporary solution. The new grout will have nothing to bond to. A larger image would help determine if there is another way to salvage. – Handy Man Jun 26 '14 at 16:49
What if I use a grout saw and then fill in with new grout? Here are larger pictures: – Zee in BK Jun 26 '14 at 16:55
up vote 3 down vote accepted
This is really impossible to answer without opening it up more. But basically it depends on the damage already done. What you really need to do is clean this shower (bleach) and take out any loose pieces. And let it sit for a week. Also try to keep the humidity in the room low too.
If nothing grows back and your tiles are structurally bonding you can grout over. You need to get rid of as much as the old grout as possible. Then you need to let grout sit a while after putting it in - at least 3-4 days. I would even introduce heat to the room and have done this before.
You need to sap the moisture and humidity out of the walls. Then you need to seal the new grout. Even if you have mold/mildew on the walls (unless it is extremely bad) it will soon die off due to lack of air/water. Note that there could be issues inside the wall or on the other side I am not addressing.
This advice is nothing more than a logical guess from someone who has flipped a lot of houses with bathrooms like these. I would normally try to look at the wall from the other side if possible and have cut out huge sections to look. If this is your only shower this is going to be tough to do but I certainly wouldn't go through the trouble of cleaning, getting rid of old grout, and regrouting before properly drying out the shower. I have demo'ed showers full of mold/mildew before with drywall behind and find almost no signs of damage. At the same time I have demo'ed showers with some mold in one corner and that water leak caused mold on everything behind it. If you can see this wall from the other side and it is concrete board (can take a tile off too) then I would be very confident in just letting this thing dry out and regrouting.
