I would like to know if it is possible to reduce a drill bit diameter (the body and not the shank). From times to times I need to work with dimensions that are not integer number or half number.... example: where I live I can only find drill bits 6mm or 6.5mm or 7mm..... however, in some cases I really need to have a dimension of 6.25mm.
Is this even possible to do, if yes how?
I imagine this would need a lathe, special cutting tools and probably a process to recreate the hardening of the drill's cutting edge? But if you have those tools wouldn't it be far better to make a bit from steel rod stock? – RedGrittyBrick Jun 25 '14 at 9:36
Use the 6mm bit, and wiggle it a bit to widen the hole to 6.25mm. If you're dealing with such precision, you should probably be using specialty tools. For reference: 6.5 mm = 0.255906 in., 6.25 mm = 0.246063 in. A difference of 0.009843 in. or ~5/512 in. (0.009765625). – Tester101 Jun 25 '14 at 11:10
up vote 6 down vote accepted
I would suggest that you look a little farther. Drill bits are available in many more sizes than you mentioned. One big supplier on-line, McMaster Carr shows available metric sizes for heat resistant cobalt steel jobbers drill bits in all of the following metric sizes:
If you can find access to a supplier that has drills on the numbered gauge scale or the lettered scale they cross reference to metric sizes as shown here:
You can buy metric and imperial drill bits.
If your local hardware don't sell both you can buy them online. (ebay) or other site.
Also if you try to machine a drill bit down it won't be as strong.
In theory, yes, you would need to remove the hardening by heating to the proper temp and slowly cooling, turn it on a lathe, mic in your specs, re-harden... Best bet would be buying more drill bits. Like recommended above, McMaster Carr is an excellent source for more tools than you thought existed. Maybe you need SAE/inch pattern? 6mm=.236in 6.25mm=.246in 6.35mm=.25in 6.5mm=.256in 3/16in=4.763mm 7/32in=5.555mm 1/4in=6.35mm 9/32in=7.142mm
I'm not sure how this answer adds any additional information? – bib Jun 25 '14 at 23:39
