I have shower tiled with travertine and along the entire bottom a thick almost rubber-like substance is slowly leaking out. It is a grey / black color. I'm assuming it is thin set that wasn't mixed properly and never completely set up. Should I be concerned, and if so what should I do about it?
How long ago was the tile installed? You may want to add a picture or two to help figure out if it's mold or something similar. – alt Jun 23 '14 at 19:39
House was built 6 years ago but it's been doing it for a few years now. When I pull it out, the part that is under the tile does not appear to be moldy. I tried to post a pic, but didn't get it to work. Thanks – user23282 Jun 24 '14 at 4:56
Hi! It looks like you’ve accidentally created a couple of accounts. If you’d like to merge them (there are some advantages to doing so), the instructions are here. Welcome to the site! – Niall C. Jun 24 '14 at 11:47
I suspect that's butyl sealant that a lazy installer used to prevent moisture from wicking up behind the tile, avoiding a trip to the hardware store. You might carefully trim it off with a razor blade and cover it with what should have been used in the first place: "tub & tile caulk".
Thinset has only two consistencies: powdery when dry and concrete-like after exposure to moisture.
Thin set that is not mixed correctly will cause the tile to lay funny. The water will evaporate once the mix sets off. If it had too much water I think your first sign would be the tile scrunching down into the hollow space below it.
If you have a Shower Door track, it could be the caulk or plumbers putty they used to seal that. Sometimes a bad batch makes into the stores and it breaks down when it is supposed to just stay pliable.
Oh, and if it was put together 6 years ago and actually has a way into the wall board out side the shower down at the corners. It could be wall board that is leaking, especially if it the Chinese wall board they had a recall on which had lead mixed in it also. Could explain the Grey and Black substances... – Johnny G Jun 24 '14 at 5:30
