My Kenmore dryer heats up a certain extent but not enough to dry the clothes in the cycle.
Okay, but what's your question? – alt Jun 22 '14 at 19:39
Gas or electric? – DJohnM Jun 22 '14 at 19:50
How old is the dryer? When is the last time you cleaned the lint from the dryer (not just from the screen)? How is the dryer vented? When is the last time the vent line was cleaned? – Tester101 Jun 23 '14 at 10:07
A dryer works by forcing air past a heating element, through the drum where the clothes are, and out a vent. If there are any restrictions in the air flow, not enough hot air will move through the system.
Let's take this dryer for example
Dryer
The motor rotates the drum, which tumbles the cloths. It also spins the blower, which draws air in through the intake, through a heater (which could be gas, electric, etc.), through the clothes filled drum, past the lint screen, and eventually out the exhaust.
Dryer Air Flow
Notice after the air leaves the drum, it takes moisture and lint with it. Some of the lint is caught by the lint screen, but not all of it. Over time, lint can build up inside the dryer beyond the screen. If this lint is not cleared out, and is allowed to accumulate. The air flow through the entire system will be restricted. Which means less hot air will move through the drum, and your clothes will not dry.
Dryer Restriction in Dryer
Another common problem, is flexible exhaust tubing.
Flexible pipe
This stuff doesn't have a smooth interior wall, which can often lead to lint accumulating in the pipe. This also leads to a restriction of air flow through the system, and again reduced drying.
Dryer Restriction in Vent
Often times this flexible tubing is plastic, which is even worse since it's flammable. If for some reason the lint in the tube ignites, the tube itself will burn as well rather than containing the fire.
tl;dr
The easiest ways to insure proper drying are:
  1. Clean lint screen after every use.
  2. Remove lint from inside the dryer (see manufacturer documentation for schedule and procedure).
  3. Remove lint from exhaust plumbing.
