I'm planning to place a shield on my front door and would like to know which of the 3 shield designs is the most secure option and why.
Basic design characteristics:
Top Left:
  • the outside part of the cylinder is covered with a black steel covering
Bottom:
  • it has another fastening screw on the top part
Top Right:
  • the cylinder is completely "invisible" (covered) from the outside
euro cylinder shields
Just a comment: If someone approaches a lock with a drill capable of drilling through it and has the intent of doing so, I highly doubt they'd be deterred by a hardened lock cover and simply give up. There is always a 'weakest point' in your security, and at best upgrading to a lock like this will simply shift your lock a tiny bit further away from being the weakest point. If it IS the weakest point, that probably means your house has no windows, re-enforced concrete walls and the door can withstand a battering ram. Sounds lovely. – gregmac Jun 18 '14 at 23:04
Effectively there should be no difference. They only vary for aesthetic purposes. Someone trying to access the door via cutting the cylinder would have to work very hard indeed regardless of which model you pick.
What's much more important is that you ensure that the rest of the door is as secure as the lock mechanism itself.
I've just realized that the Top-Right is probably the most secure because since it is 100% covered, it is also anti-drill, unlike the other two. – Matías Casado Jun 18 '14 at 13:01
If I'm drilling a lock, I'm not coming in from the side... – The Evil Greebo Jun 18 '14 at 13:03
Door and casement are the weak spots, nobody's going to bother drilling a lock if they want in, even in the country where they'll be undisturbed. There are a lot softer spots for entry than the door. An alarm system with glass breakage detectors is actually more safe than any door lock you can buy. Defense in depth if you're really concerned. – Fiasco Labs Jun 19 '14 at 4:14
@TheEvilGreebo - Yep, Drill bit down through the keyhole, self-tapping bolt and a slide-hammer puller is the usual means. Guts the cylinder right out of the housing and gives you direct access to the internals. Less noisy methods are used IRL for nefarious activity. – Fiasco Labs Jun 23 '14 at 20:30
