Around the outside of the house, the concrete base is covered with a layer of styrofoam and a layer of this flexible stucco material. I'm not really sure what exactly is. This sheet looks like stucco with a plastic mesh through it (see images).
I'm trying to fix the damaged parts and I would like to use the same materials or something similar which would be very close to what it already is.
Front of the stucco layer:
Front of the *stucco* layer
Back of the stucco layer:
Back of the *stucco* layer
Undamaged wall:
Undamaged Wall
Damaged wall:
Damaged wall
up vote 1 down vote accepted
What you have is a system called EIFS for short. Here is a link to get to the care and repair of this type of finish.
Sto Exterior Insulation and Finish Systems (EIFS) Manuals: StoTherm EIFS Repair and Maintenance Guide
Link only answers are only helpful as long as the link is good. Please consider summarizing the information found in the link here. – Tester101 Jun 16 '14 at 10:18
It has the answer in there, I figured to have the whole maintenance and repair manual might be handy. On top of that I have never tried to get a PDF on Stack. I will try to abbreviate it – Jack Jun 16 '14 at 12:26
