My house appears to be sheathed in some kind of fiberboard product with a black paper facing on the inside. That rock-looking thing poking through is stucco. The house was built in 1972. Anybody know what exactly this material is? Good or bad? Is it evidence of shoddy, terrible construction? Can this stuff be expected to hold a screw if you wanted to screw something to it? Am I the one who's screwed? ;-)
up vote 2 down vote accepted
The material you have there is what I was taught to call celotex. There is a manufacturer that has the same name that may have been the original maker of this product.
It is pretty much the equivalent of loosely packed sawdust drawn into a sheet and held together by binding agents and tar, I believe on the outside surface. Research on ther internet may show it is made up of something else, never the less it is not that strong, and would not work as windbracing on its own. Many, many home have this under their siding.
It will not hold a screw, it is used for sheathing only that I am aware of in all my years. You are not screwed for having it, just like any other sheathing, you don't want it to get exposed to water, especially this stuff.
Thanks Jack, as always! – iLikeDirt Jun 10 '14 at 1:54
Back in the late 60's early 70's we used a similar material called BildRite that was applied as sheathing. It was promoted at the time as having better insulating characteristics than plywood or wood boards. It was also significantly lower cost.
The stuff cannot support fasteners. Anyplace from the outside where fasteners must be used there has to be backing nailed into the stud cavity.
