I am building a home and would like to install floor tiles on wall also, please let me know if it possible to install floor tiles on walls?
What kind of floor tiles? – bib Jun 9 '14 at 13:56
The floor kind. ;) – The Evil Greebo Jun 9 '14 at 17:52
Yes.. Make sure you using a strong tile backing and not plasterboard! – Matt Jun 21 '14 at 4:26
Yes, it is possible to install floor tiles on walls.
Yes you can use almost any tile on either wall or floor, the only things that differentiate the two would be
  • Texture and surface smoothness - rough tiles are made for floors to be anti slip when wet
  • Design and pattern - the design is often more suited to floors or walls
  • material thickness and strength - the stronger (hence thinner) materials are more compatible for walls since they will be lighter and less likely to fall off. (ie porcelain or ceramic)
The important thing is that you use a wall adhesive for walls and floor cement for floors, since the wall cement will have more adhesion strength to hold up the tile.
As the The Evil Greebo said it is possible one of the factors to consider is the weight of floor tiles on wall as they are generally thicker/heavier. Hence they can be more difficult to lay on the wall.
I thought the depth of my answer should reflect the depth of the question. ;) – The Evil Greebo Jun 9 '14 at 13:18
protected by Community Jun 20 '14 at 10:05
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
