Tell me more ×
As you may know I asked a few questions to this end already and just wanted to know if I should remove the nails and replace them with screws to hold the 1/2" plywood sub floor securely to the joists so that I will not get noise in the new floor?
Or is that overkill and adding a screw near each nail is good enough?
Once the flooring goes down I don't get a re-try so I would rather get it right the 1st time.
1 Answer
up vote 9 down vote accepted
You should not need to remove the existing nails. Driving a new screw into the joist adjacent to the nails should be sufficient.
You may need to countersink the screws to get them to sit flush.
for sure, the screw will sit nice and snug in the plywood ! – kacalapy Feb 1 '11 at 17:26
+1 and screw size should be chosen properly. If screws are too small they just won't hold the subfloor reliably and it will start squeaking sooner or later. – sharptooth Feb 2 '11 at 6:32
@sharptooth what size would be needed for this? i was going to use 2" screws – kacalapy Feb 2 '11 at 13:55
@kacalapy: I'm used to millimeters - I'd choose at least 4 mm in diameter and at least 20 mm in length, preferably longer. – sharptooth Feb 2 '11 at 14:06
It helps if the screw shank does not have threads on the portion that is in the plywood (1/2" in your case) when the screw is fully seated. This allows the screw to pull the plywood down to the joist. – Les Oct 1 '12 at 15:40
