I have a broken B22 'bayonet' style light socket. One of the grooves that holds the bulb lugs has snapped off. How can I replace it, and what to look for in a replacement? enter image description here
up vote 1 down vote accepted
Replace the whole thing.
Turn off power to the lighting circuit. Check, then unscrew the top white part and use a screwdriver to undo the screws holding the wires/
Any hardware store will stock replacements.
Some have metal to retain the bayonet pins, which is probably stronger than all-plastic construction.
