There was a problem with the pipes under the floor, which resulted in several ceramic tiles being removed. At the moment these tiles are back in place. The problem is that 2 tiles next to them, that weren't completely detached, were glued back by injecting typical silicone under them. The problem is that now they balance a bit when we step on them.
The silicone method was suggested to me, and didn't work well. The tiles are being slowly taken off, moreover the tile grout cracked several days after because of that little movement.
My only idea is to inject some more silicon under the tiles, and fill the gaps using typical grout.
How can I glue these 2 tiles back without taking them off?
Note: There is a fair amount of silicone under the two detached tiles, there is no point in injecting tile grout.
You can't. The only way to make a reasonable repair is to remove the tiles so they can be reset properly. – Ecnerwal Jun 2 '14 at 1:38
up vote 1 down vote accepted
Silicone is supposed to allow movement and give. I cannot really think of anything worse to glue tiles to a floor. You need to take the tiles off, scratch off the silicone and reattach them with thinset. After that you can grout.
If you keep applying the silicone you will keep getting the same result.
