I want to build a simple steam machine for steaming wood to bend.
To do this I must place the wood into a sealed PVC pipe and pump steam into it. The PVC pipe part is the easiest part. Producing steam in a simple and economic way is where I need help.
I was thinking of simply using the element from an electric kettle, but these use quite a lot of electricity - the wood must be steamed for at least an hour. I also looked at a clothing steamer, but these seem too weak.
'Pumping' the steam into the PVC pipe is not a problem, as long as the pipe is higher than the steam source, so there is no need for forced induction.
Has anyone built something like this before?
Would anyone know a way of building a simple and cheap steam making machine?
