The light that is attached to my garage door opener no longer turns on when I open or close the garage. I have tried incandescent and CFL bulbs that work in other lamps. Any ideas of what may be wrong or how I can troubleshoot the problem?
Following Grunthos's answer, I found that the connection at the bottom of my socket was corroded. With the garage door opener unplugged, I scrapped away the nasty with a flat-head and now my fiancee thinks I'm a hero!! – michaelkoss Jun 4 '14 at 14:32
up vote 3 down vote accepted
Garage door openers are subjected to a lot of vibration in normal use. There are even special garage door opener incandescent light bulbs which have a stronger filament than usual, to resist breakage from shaking.
Since you've tried different bulbs, the next most likely issue is a bad connection at the socket. It could be in the socket itself. There is typically a little metal tab or "tongue" in the bottom of the socket which contacts the base tip of the bulb. If that is bent down too far, it won't touch the bulb and light it up. You can check this with a volt meter to see if you have power between it and the sidewall of the socket. If you have power but no light, this is probably the problem. Unplug the opener, and reach in to the socket with needle-nose pliers and pull the metal tab up, to make better contact with the tip of the bulb base.
Also, check the socket for rust or corrosion. If you have any, you can sand it clean with a little sandpaper.
If you check with a meter and don't have power at the socket, then you may have a broken wire or wire connection to the socket. You'll have to unplug and open up the opener to inspect the wires.
When I'm using the volt meter to check if there is power running through the tab at the bottom and the sidewall of the socket, which is the positive and which is negative? Or does that even matter? – michaelkoss May 30 '14 at 19:20
No, positive and negative don't apply here. You are checking for AC (alternating current) voltage, so each side alternates back and forth between positive and negative. However, this means it is important that your meter is switched to measure AC and not DC. It may also have a switch setting for voltage range, which needs to be set to whatever is above 120 volts. So for example, if your meter has switch settings for 20V and 200V, set it to 200V. You'll need to measure it when plugged in, when the light should be on, so be careful with your fingers near live voltage. – Grunthos May 30 '14 at 20:36
Thanks, Grunthos! I'll check it tonight – michaelkoss May 30 '14 at 20:54
