I am slowly replacing my galvanized plumbing, piece by piece with PEX and Sharkbite connectors, and it got me thinking: do I need to keep the risers?
Do you mean that you want to connect the PEX directly to fixtures? What about the shutoffs? – Tester101 May 29 '14 at 21:46
Currently, I have just replaced the horizontal galvanized runs in the attic, leaving the vertical pipes in the walls. Where the horizontal run meets the vertical drop there is usually a T with a riser to prevent water-hammer. Do I connect to the T or can I remove the T and connect to the vertical drop? – MarkTheMule Jun 2 '14 at 16:29
"Sharkbite connectors" ??? I hope you're not using push connectors. Plumbers usually deem those as unreliable. – Dannyboy Mar 9 '15 at 13:39
