In my kitchen I had a ceiling light which I turned on and off with a wall switch. I replaced the ceiling light with a fan/light combination. When wiring the instructions did not tell me what to do with a single red wire coming from the electrical box. I figured it was a ground wire. The fan motor had a green ground wire which I did connect. I just capped the red wire from the electrical box and continued with the installation.
When I finished and turned the electricity back on, I was unable to activate the fan/light from my wall switch. I could only activate it with the pull chains on the fan/light. Should I have connected the red ground wire with the green one that was part of the fan/light? No remote came with the fan/light.
I have not done anything to change my original installation.
closed as unclear what you're asking by Tester101 May 29 '14 at 18:12
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question.If this question can be reworded to fit the rules in the help center, please edit the question.
Stop what you are doing. Are you in the US? – Edwin May 28 '14 at 15:20
STOP!!!! you are gonna get in trouble. The red is probably hot or switched. the green is ground. Get some help before you burn down the place or hurt yourself. – shirlock homes May 28 '14 at 15:50
do you have and know how to use a volt meter? – shirlock homes May 28 '14 at 15:55
How was the original fixture connected? – Tester101 May 28 '14 at 16:29
You're going to have to add a bit more detail. Please list all the wires (including their color and which cable they come from), excluding those from the fan/light (since we can assume there's black, blue, white, and green wires from the fan). It also would be helpful if you listed all the wires that are in the switch box, and where they're connected. Photos and/or sketches would be ideal. – Tester101 May 28 '14 at 19:07
If you don't know how to use a test device of some sort -- at least a voltage probe light -- you really should not be taking apart and reassembling your house wiring. The chance of hurting yourself or someone else is too high. Get a more knowledgeable friend to do the project with you, teaching you as they go.
Having said that...
The house-wiring color code is fairly well standardized, at least if whoever installed the circuit was vaguely competent. A table giving the conventions for multiple countries can be found at http://www.allaboutcircuits.com/vol_5/chpt_2/2.html
In the US, the black wire would normally be the "hot", or powered, connection and the white wire would be the "neutral", or return, connection. The switch should be on the hot side. So a lamp is normally connected to the black and white wires, with the safety ground (green or bare) wire running to the body of the fixture to ensure that a short circuit, if one ever arises, causes the breaker to blow rather than zapping a human.
A red wire, in the US, is the "second hot". This is used when two circuits are run through a single cable. It's sometimes used for the connection between two-way switches (the first switch selects which of the two will be powered, the second switch selects which of the two will be connected to the controlled circuit, so the two switches have to agree before electricity flows). It's also sometimes used in exactly the situation you're describing, when there are two wall switches independently controlling two parts of a single fixture (the fan and the light, for example).
The fact that the red wire is present at all in a US installation would tell me that the box the fixture was mounted to had probably been wired in some specialized way, or at least that whoever installed that wire expected to need that wire later. (In the latter case, it may not be connected to anything at all right now.) If you can't figure out what controls that red wire, capping it with a wire nut and tape was almost certainly EXACTLY the right thing to do.
So... If that's what you've done, and you aren't getting power, either your connections are wrong or they're bad electrically. Cut the power, dismount the fixture, review the instructions that came with it, review how you actually had things connected (no assumptions!), make sure that you have connected the wires to each other properly, make sure no bare wire was exposed that could have caused a short and blown the breaker... did you check that the breaker hadn't popped? ... and fix whatever you've done wrong. If you can't figure out what you did wrong, go get that more experienced friend and have them look at it. First thing I'd do, since you didn't note how the old fixture was connected, would be to determine whether the circuit really is wired as the colors promise, and whether the wall switch you're using controls the black wire or, possibly the red. (Or was installed in the neutral, which would be WRONG but is unfortunately possible in circuits installed by amateurs.)
WARNING: Ceiling fans are heavy and they vibrate. It is generally considered a Bad Idea to hang one from an electrical box that previously carried a lamp fixture unless you KNOW that it is unusually well secured and will not work its way loose and drop the fixture on someone's head. If the box isn't screwed directly to a joist -- and I suspect even if it is, by code -- you'd want to replace that box with one designed for the purpose, screwing the ends of the hanger bar into the joists on either side of the opening and bolting the box to that bar.
It is also possible that it was originally wired for a fan/light combo and the red is a second switched hot for the fan. +1 for bringing up proper fan support. – Comintern May 28 '14 at 22:37
@Comintern ... And if so, when they went back to a simple light they might have kept the red and disconnected the black -- which would be bad form but not technically incorrect. If so, simply replacing the black with the red (and capping the black) might solve the problem. But it'd be better to test this theory with a probe BEFORE reconnecting the fan, just in case a previous owner did something (ahem) "creative". – keshlam May 28 '14 at 22:54
Agreed on testing first. If the red was a second switched line to the fixture it would also be present (and hopefully capped) in the fixture box. – Comintern May 28 '14 at 23:04
