I'm ready to reroof my house and want to consider an elastomeric coating rather than replacing the existing shingles. I'd use a local contractor either way
If what you are asking is if you should coat old shingles with a elastomeric coat instead of tearing off the old and replace with new, I think the answer is no. Such rubberized compounds are normally used for short term repairs (2 to 5 years) on damaged shingles on a pitched roof, and as a seam sealer on rolled roofing for flatter pitches. If your shingles are failing, coming loose or have cupped or distorted with age, coating them most likely would be a very short term fix. The underside of the shingles will continue to fail, making an expensive coating project a waste of money in my opinion.
If I have missed the point of the question, I'm sorry. If the situation is different, the answer may change a bit. But normally, i'd never use an eleastomer coat over old worn out shingles.
I'm asking if it's advantageous to tear off the shingle roof and install an elastomeric roof over the original decking instead of new shingles. The house has a typical pitched roof with the usual hips and valleys. – tuc1labar May 27 '14 at 16:14
Are you talking about a roll on like Grace Ice and Water Shield? – shirlock homes May 27 '14 at 19:11
I don't yet know enough to answer that question. Years ago I helped roof an addition that included a fabric base with an elastomeric top coat. I'm picturing something similar-all of the leak protection of shingles, easy maintenance and high (70%) reflective value to help keep the roof cool. – tuc1labar May 27 '14 at 19:46
not sure what product you are talking about. Up here in the north we use Grace for a shingle underlayment. Most elastomers are in a liquid form and come in 5 gallon buckets. – shirlock homes May 27 '14 at 20:07
Here in Southern Oregon, we have a company called Duro-Last that fabricates Elastomeric Membrane Roof covering. You can get a whole prefab roof or by the roll for contractors. – Fiasco Labs Jun 27 '14 at 1:16
Shingles have the advantages that one would associate with a well understood conventional technology, those implicit in a large tradebase of competent installers and those that come with a long history of successful installations on residential and commercial structures.
Elastomeric roof coatings have all the advantages that come from lacking these features.
